Vox 300
The VOX 300 extends the high-end VOX series upwards. While the mid-to-high-range is the same as in the VOX 252, the TIW 360 8 OHM has been chosen as the woofer for this model. As a result, while the excellent characteristics experienced in the mid-to-high range remain the same, the level accuracy and dynamics in the bass department have been increased and the lower limiting frequency reduced to a remarkable 23 Hz. The VOX 300 can, therefore, be seen as the VOX variant for high-volume aficionados who like to hear concerts at close to the original sound levels in large rooms.
Rated power | 300 W |
Maximum power | 600 W |
Nominal impedance Z | 4 Ohm |
Übertragungsbereich (-10 dB) | 23 - 25000 Hz |
Net volume | 100 l + 4 l |
Außenmaß Höhe | 1225 mm |
Außenmaß Breite | 260 mm |
Außenmaß Tiefe | 455 mm |
